2001 Boxster owner
A few drops of oil...
I've been parking the Boxster in the garage lately and seen a few drops of oil on the floor from below the engine?
Is a cause for concern? Normal?
Should I begin seeking IMS Failure Therapy?
Just curious.
Old 05-14-2011, 10:39 AM
Have you changed your AOS yet?
I noticed a few drops of oil here and there.
After I change out the AOS the drops were gone.
(AOS) Air Oil Separator . they tend to leak when failing or has failed.
Hope that helps.
You can buy one here at Pelican Parts.
Old 05-14-2011, 06:34 PM
srg srg is offline
One likely source is the O ring seals on the spark plug tubes. The O rings are inexpensive and Pedro (search Pedro's Garage) has a write up on how to replace them yourself - I did it on my '01 and it was pretty easy.
Old 05-16-2011, 07:47 AM
Lots of potential sources - a few drops could be irrelevant (cam covers) or could be significant (engine/trans mating area) depending on the location. Take a look and let us know.
1999 996 C2 sold - bought back - sold for more
1997 Boxster BSR POC/PCA #254
1978 911 SC Daily Driver
Licensed DE/TT Instructor
Old 05-16-2011, 01:42 PM
2001 Boxster owner
The oil drops heard that I posted about them here, and have not reappeared.
Old 05-17-2011, 08:40 PM
Alphaboy1's Avatar
Oil Drops
I also seen 2 drops of oil the size of a dime since I have owned the car for a year. Did you drive the car hard the days the oil appeared? I noticed it was those days that this happened. And also have not seen anything for 6 months.
Regards
Paul
Old 05-19-2011, 04:02 AM
2001 Boxster owner
That sounds about right. 2 dime sized drops that have not reappeared.
Now if I could only figure out if my car "sounds right"... it can sound kind of clattery when going in reverse.
Old 05-19-2011, 01:04 PM
