-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Can't insert Ignition Key (http://forums.pelicanparts.com/boxster-cayman-forum/609478-cant-insert-ignition-key.html)
Greg986 05-18-2011 08:53 PM
'Have 1999 Boxster. 'Had difficulty removing ignition key. 'Finally removed it. Now I can't insert key.
'Common problem? Am I looking at needing to replace ignition switch, or am I not aware of simple solution?
messex 05-19-2011 03:56 AM
It is my understanding that it is a common problem that there is a piece in the switch that 'breaks' easily. Supposedly common. I had it where when I pulled the key out, the system still thought the key was in, and it left everything 'on' and 'dinging'. I believe they had to replace the switch (been a while, so can't remember). I do remember, though, that my mechanic said he had replaced a bunch of them with the same issue.
Now, if you can't get the key in, not sure how you get it to the mechanic!
Doug&Julie 05-19-2011 09:07 AM
See if this helps...
Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987
SmileWavy
