s_wilwerding's Avatar
Anti-seize on header bolts
I'm about to install my new exhaust, and have ordered 12 new header bolts (since the existing ones have been on and off a few times). Any issue with using anti-seize on the bolts?
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 05-20-2011, 11:49 AM
JFP in PA's Avatar
Should not be an issue.
Accrochez-vous bien de vos rêves..........."
Old 05-20-2011, 12:32 PM
turboflyer's Avatar
Use the extra high temp copper compound anti seize if required. Hopefully they will not loosen up. Engine are relatively smooth running. Typically a light coat of oil and torque to spec. I think if I used the anti seize I would want to add the fancy anti back off tabs, not sure the actual name.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 05-21-2011, 06:19 AM
JFP in PA's Avatar
The copper compound holds up well; a really slick option would be to use it and find brass replacement nuts, which stay tight but can be easily removed and replaced without any stud damage in the future..............
I think you are refering to Stage Eight fasteners:
Old 05-21-2011, 08:25 AM
turboflyer's Avatar
That would be it. Yep copper is used on many aircraft header nut, but metric may be a problem.
Old 05-22-2011, 06:53 PM
I've been using copper anti-seize in the field for 7 years now without fail. I prefer to use new hardware as well but I've never had a properly assembled exhaust system come loose. Makes disassembly down the road much smoother, cause NO one likes a broken exhaust manifold bolt!
If you don't live life on the edge, you take up too much space.
Old 05-22-2011, 09:35 PM
Make sure you use Silicone-free anti-seize compound or you would run the risk of damaging your oxygen sensors.
Old 05-22-2011, 09:54 PM
