Mufflers for Boxster Spec Racer
I'm building a BSR. Just finished the IMS bearing and deep sump, and now I'm thinking about the exhaust.
I am hoping that someone can make a recommendation for some mufflers. Just something to take the edge off without adding too much of a restriction.
TIA
Michael
Old 06-05-2011, 08:01 PM
s_wilwerding's Avatar
I saw two Spec Boxsters this weekend at our Club Race - both had exhausts that hooked directly to the headers and went straight back. I have no idea what the brand was, but I'm sure they are available somewhere, since they were identical on both cars.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 06-06-2011, 05:53 AM
This is not an endorsement as I have no experience with this system, but AWE Tuning came out with a straight-pipe system specifically for BSR:
Introducing the AWE Tuning Porsche Spec Boxster Bolt-On Exhaust System - Rennlist Discussion Forums
Alternatively, I know a few guys that have just done straight-pipes on their own as cheaply as possible, even leaving the cats in the system.
Old 06-08-2011, 05:35 AM
This guy has what you need: PORSCHE BOXSTER SPEC - PRECISION CHASSIS* WORKS***
Old 06-08-2011, 08:19 PM
Platinum Member
dad911's Avatar
For a quick solution, I just removed the mufflers and replaced them with 2-90 degree bends. Left the cats. While not optimal, it was inexpensive and quick.... I know a few racers that have done this.
Old 06-09-2011, 06:10 AM
Tube diameter and slight back-pressure via a straight thru muffler are key to making the most power from a Spec car. Straight pipes will actually loose torque down low and do not achieve max HP up top contrary to popular belief. Too small a tube and it will be restrictive (stock diameter leaves a lot on the table) and too large a tube will sacrifice torque and will not yield more HP up top. 2" tube with a small straight thru muffler is the best combination for Boxster Spec cars.
Old 06-11-2011, 01:10 PM
So after measuring, the longest muffler I can "easily" fit is a 12" or maybe a 14" glasspack. I'm going to mock up some tubs tomorrow to see if I can make that work.
BTW, after 120,000 miles the IMS bearing looks perfect.
Old 06-11-2011, 08:44 PM
Tags
bsr , muffler
