newlife
Engine Management Education
Hi
I ordered the book, Bosch : Fuel Injection and Engine Management from Wayne but they no longer carry the book. I was wondering if anyone knew of a good book that was compreble. I ordered Wayne's book and Bentley. But since I am now a proud owner of my 2000 S I want to learn more about how exactly the Porsche engine works. Your comments are appreciated. Rod
The little I know I learned from reading the Porsche DME manual itself where, in discussing the trouble codes, it goes into some detail in the theory of engine management and how the sensors connect and what they tell the DME.
newlife
Hi Mike,
Just to let you know... your advise has been proven very helpful. My Porsche is running smoother and it did pass the smog thanks to you. Mike, where can I get the Porsche DME manual you are talking about. Sounds about what I am looking for? Rod |
Paul V
I've never seen the DME manual that Mike is speaking about, but there's some good info in these manuals:
Planet-9 - Downloads - Misc / Other Look at the After Sales Training pdf's. Engine Mgt Systems and Advanced Engine Mgt Systems both have some good info. Regards, paul...
----------------------------------------------- 07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X |
newlife
Wow,
thanks Paul.. Rod |
Book is available at Amazon.com:
Amazon.com: Bosch Fuel Injection and Engine Management: How to Understand, Service and Modify (9780837603001): Charles O. Probst: Books I have read this book and its very helpful in understanding the premises of DME operation.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor |
And before someone asks, the manuals are no longer in print (originally cost $2,300 without the seperate $1,800 OBD II diagnostics manual) and very hard to find.
Accrochez-vous bien de vos rêves..........." |
newlife
Thanks JFP,
I appreciate the post. Rod |
newlife
Rod |
newlife
I ordered the book yesterday, I will check for you once I recieve it. Rod |
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 06-08-2011 at 01:39 PM.. |
Crazy Austrian http://www.ws-ab.com |
Don't get me wrong - this is a very good book and will give you a good understanding of digital engine control, feedback loops, various sensor inputs and how the DME adjusts for various conditions. You'll need to know this stuff if you want to understand more specifically how a Porsche DME works but the Porsche specific stuff isn't in this book. To answer your question directly, I believe that RKAT = Adaptation in range close to idle (Bank1) Simply put, this is one of several adaptation values that the DME has calculated and stored to "trim" the air/fuel mix in order to maintain performance and emissions. This adaptation process is discussed in the book, but the exact terms (e.g. RKAT) are not in the book.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor Last edited by thstone; 06-08-2011 at 11:03 PM.. |
Paul V
Some meanings of the parameters
RKAT (b1 or b2) = Long Term Fuel Trim (banks b1 or b2) at Idle. MAF needs to show 12-32kg/hr. Adaptation range is 0.00 to +/- 3.50 mg/stroke (mg of fuel per intake downstroke).
FRAU (b1 or b2) = Long Term Fuel Trim (banks b1 or b2) under load - lower range. MAF needs to show 32-220kg/hr. Range is 0.0 to +/- 35%. The tank vent valve needs to be closed when testing this. FRAO (b1 or b2) = Long Term Fuel Trim (banks b1 or b2) under load - upper range. MAF needs to show 220+kg/hr. Range is 0.0 to +/- 35%. The tank vent valve needs to be closed when testing this. HTH. Regards, paul...
----------------------------------------------- 07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X Last edited by paulv; 06-09-2011 at 04:45 AM.. Reason: typo |
newlife
Rod |
The stuff over at Planet 9 in the files section looks like interesting reading but I'm not able to download any of it, even after I registered on their system. I get a message that says it's not shared to me. Anybody else run into this, or how to fix it? Is it for paid members?
Paul V
Regards, paul...
