going back to stock air filter
First off i wanted to say that this is a great site with a lot of information and great advice.
I have 2001S (bought in 2006) and finally started doing my own work after reading through everything here (has helped to remove the intimidation factor).
So after accessing the engine i discovered the air filter has been replaced by what appears to be an AFE cone filter. Since i have never seen the stock air box i am wondering what i would need to go back to the original air filter.
Thanks for any help.
Marty
Old 06-10-2011, 06:48 AM
turboflyer's Avatar
So the previous owner did not give you the original air box? Thats not going to be cheap. Not a big deal just parts and a PITA. Get the parts diagram and check a salvage place first then order what you need. Good time to clean and or replace the MAF sensor if it is dirty.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 06-10-2011, 07:12 AM
Jupiter 911
bklyn's Avatar
Marty for what its worth you should go back to the original air box, I have experimented with cone filters, oil type and dry types and always seem to have a problem. They would either foul the MAF and set off the CEL or gum up the throttle housing and cause a rough idle. Went back and never had a problem.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 06-10-2011, 08:17 AM
ronster's Avatar
I've used K&N filters for years, and currently have an EVOM CAI on my '99 Boxster, and have never had a MAF or CEL issue. The main reason these issues show up is from over oiling after cleaning. Most owners use way too much oil and don't allow the filter to sit for a day after oiling. If you use half as much as you think you need then let the filter sit for a day you shouldn't have any problems. EVOM has also come out with a "dry" cone filter that acts like an oiled filter. If you go back to the OEM be prepared for some work as the air box and sound chambers require you to loosen or remove the manifold on that side to squeeze it in then you have to access two screws on the bottom that typically require you to get the car up to get to them.
Old 06-10-2011, 08:28 AM
Thanks for all the feedback. I bought the car from a local exotic car dealer who had imported it from the US, and he had no paper work or anything. Live and learn. Obviously after reading through here and getting a couple of codes related the MAF i decided to tackle it myself and clean it(or replace if necessary). This is when i discovered the filter, and based on what i have read in regards to oiled filters it has started me thinking about getting back to a non oiled type.
Funny thing is when i bought it i took it to the Local Porsche shop and had them do a thorough going over. They never mentioned anything related to the air filter.
Old 06-10-2011, 10:26 AM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
What is your location?
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 06-10-2011, 11:05 AM
Sorry, should have mentioned - Calgary, Alberta Canada
Old 06-10-2011, 11:48 AM
JMatta's Avatar
I've had the Evo Hi-Flo cone filter on my car for five or six years...have never had an MAF or CEL issue. As mentioned earlier, virtually all problems occur from over-oiling. I clean my filter, re-oil, then wrap in newspaper to remove any excess. There's absolutely no reason a dry element cone filter would cause a problem, if you don't want an oiled variety. The sound is every reason not to re-install the factory air box.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 06-11-2011, 08:31 AM
I was just thinking about that this afternoon. So there are cone filters that are a dry element that i could swap in place of the oiled?
Old 06-11-2011, 05:37 PM
JMatta's Avatar
Yes, Google AEM Dryflow Air Filters...they come in many shapes and sizes.
2002 Boxster S
Old 06-12-2011, 06:13 AM
