Exclamation Boxster rear water baskets?
Do someone know about this? Someone was telling me that it is very important to check the rear water baskets on the Boxster's, those baskets are supposed to collect and drain rain water from the convertible top. This fellow told me be sure thosee drains are constantly clean, if not, water could run under the seats and even get to an electronic module there...
Does someone knows about this?
Thanks in advance for any help on this matter.
Old 06-24-2011, 04:07 AM
srg srg is offline
Put your top in the service position (part way down). Looking into the tops boot/recess, there is a molded foam piece with the drainhole on the far left and another on the far right.
SRG
Old 06-24-2011, 06:34 AM
SRG
Thanks a lot, I'll be making sure those drain holes are clean.
Best regards!
Old 06-24-2011, 07:45 AM
nosnow4pc's Avatar
You also want to make sure the drains in the front cowl also stay clean.
99 Boxster 5-speed
12 Acura TSX 6-speed
Old 06-24-2011, 06:02 PM
