-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Engine Temp Gauge - Probably a Dumb Question (http://forums.pelicanparts.com/boxster-cayman-forum/615915-engine-temp-gauge-probably-dumb-question.html)
ASD 06-18-2021 01:43 PM
i am aware
ASD 07-03-2021 10:02 AM
Well my son pulled the bumper cleaned out thd mess , installed gril mesh.and on my way home it hit 250 red light came on.pulled over to let it cool.. guess i ll take it to a shop next for water pump inspection. crap!https://uploads.tapatalk-cdn.com/202...d810cb6bad.jpg
Sent from my SM-G991U1 using Tapatalk
ASD 07-09-2021 04:08 PM
turns out, bad thermostat, waterpump , heater control valve.
I added a new cap too.
ASD 08-09-2021 12:42 PM
Now in 90 plus outdoor temps it is running about 190.
Ranyo 08-23-2021 01:47 PM
2000 986 S in AZ yesterday. Air temp 116 running with AC on temp gauge read 180 .but the red light was flashing.. Can anyone tell me why?
JFP in PA 08-23-2021 02:03 PM
Four functions of the coolant warning light:
1. Engine coolant level too low
— light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high
— light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high
— light is lit; pointer on the right
4. Temperature sensor at water outlet faulty
— light flashes rapidly (1 Hz); pointer on the right
Note
The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously
(1Hz = 1 flash per second. 0.5Hz = 2 seconds per flash)
987.1 08-27-2021 07:36 PM
lo temp thermostats
Lo temp thermostats, do not make your car run cooler. They only open up the system at an earlier temp. So if it is quick coffee run, there might be a small advantage. But 20 minutes+ it is what is.
BTW, PCA has a YouTube video on front bumper removal and cleaning of your radiators.
cheers
Art
JFP in PA 08-27-2021 09:49 PM
I wouldn't bet on that..................
Bob Hancock 08-31-2021 07:20 AM
Originally Posted by JFP in PA (Post 11365644)
I would also suggest you install grill screens in the bumper to prevent it reoccurring in the future. I have Zunsport inserts in my personal car, years old and still look brand new, and have never had to clean out the radiators again. Once and done..............:)
I can't find these grill screens for the 2001 986 Boxster S. Might you have a link for these? The ones Pelican comes up with are rennline.
Thanks.
Pedro '84 Coupe 08-31-2021 07:32 AM
I've also had no luck finding grilles for my wife's 2000 S. Saw this vendor in an ad in this month's Panorama. https://www.radiatorgrillstore.com/product-page/porsche-986-boxster-s-small-front-radiator-grilles
JFP in PA 08-31-2021 08:47 AM
Thanks.
I got mine thru Amazon, they carry them.
Bob Hancock 08-31-2021 12:02 PM
I checked this out and alas I have the wider grills so no-joy with this one..
Bob Hancock 08-31-2021 12:07 PM
Originally Posted by JFP in PA (Post 11443035)
Got it! Thanks JFP.
Pedro '84 Coupe 09-07-2021 08:30 AM
Thanks for pointing that out. I have the wider grills too. Glad I didn't order those :)
ASD 09-15-2021 06:35 AM
i paid $39 for two sheets that i cut to size for mine.they look great.
