Welp with radiator fan
My Boxster is running a little hot and my radiator fan doesn't seem to be coming on ??
Old 06-26-2011, 07:13 PM
turboflyer's Avatar
If your close bring it over and I will test it. But depending on the area and miles it may be spring cleaning time. Time to pull the front bumper and and clean the mulch out and straighten fins. Could be a lot of things. If your close bring it over and I would be glad to turn the fan on remotely for a test.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 06-27-2011, 08:14 AM
Out of curiosity, what is the process for turning on the fans remotely? Only one of my fans seems to be coming on and I was planning on replacing it, but if I can test the fan operation first that sounds like a better plan.
Old 06-27-2011, 10:44 AM
turboflyer's Avatar
You will need a program on a laptop to do it through the OBD2 port. Well there are other ways, but the easy way. May be a relay or fuse.
Old 06-27-2011, 07:03 PM
Ah, got it. The relay is an interesting thought. The fuse looks good but I will definitely see if I can check the relay before digging into the fan itself. I'll post back here when I get around to it.
Old 06-28-2011, 08:13 AM
The Durametric unit will allow you to turn the fans on manually for testing. You can test both the high and low speeds separately. There's a bunch of stuff you can cycle for testing with the Durametric. I've used it for the charcoal cannister valves and the evap solenoid as well as the fans.
Old 06-29-2011, 04:44 AM
turboflyer's Avatar
Yep, thats the program I use. You will need a virtual microsoft emulator to run on A Mac unless they have changed that.
Old 06-29-2011, 07:42 AM
