-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Need help for 08' Cayman S timing (http://forums.pelicanparts.com/boxster-cayman-forum/618142-need-help-08-cayman-s-timing.html)
kzsport 07-08-2011 01:24 PM
Hi
I'm new in this forum.
I want to know the timing check procedure of 08' Cayman S(M97.21).
Is this timing check procedures the same with 986??
If not,what different of assembly engine detail in these 2 vehicles??
Will very Gratitude for any advice.
Brian;)
s_wilwerding 07-08-2011 01:41 PM
I'd say if you're doing cam timing (which is I assume what you're talking about), it would probably be best to pick up a Cayman factory manual. My guess is that the Boxster manual of the same vintage would work, but if it were my engine, I'd get the Cayman manual.
kzsport 07-09-2011 11:50 AM
Yes,
I'd like to engine assembling due to burn 1st connect rod bearing and crankshaft on 08' cayman s.
Just want to make sure correctly manual I had.
Of course.marked all bolta,items while disassembling and storaged well.
Will start this project on tmr...
