What tool to remove the Tip fill plug?
I want to check the fluid level on the Tiptronic in my 2000 S. Nothing I own seems to fit the plug. I thought it might be one of those double ended wrenches in the tool kit but I couldn't get those to fit either.
The Pelican article shows a 17 mm hex wrench to remove the drain plug but I didn't see what it takes for the fill/check plug. |
I saw a DIY for the 996 and it showed the drain plug being 8mm Allen and the fill being 17mm Allen.
PM me for the source of the DIY. Regards, paul... |
Thanks again for you info, Paul.
| All times are GMT -8. The time now is 03:40 AM. |
