ProjectM96's Avatar
When I brake, horn beeps?
I drove through D.C. today, which probably has the worst roads in the world. Very bumpy.
Anyways, I was driving pretty slow, 20mph. And after I went through a few bumps, I realized that when I stepped on the brakes hard trying to avoid bumps, my horn kept beeping.
The harder I braked, the longer the horn beep went. Any idea's?
Porsche Boxster 986
Old 07-23-2011, 09:53 PM
I had a similar problem. 'Could be grommets on air bag mount have deteriorated, allowing connection to set off horn. I believe it's project #62 (in "101 Projects ...")that covers removing that part as part of Steering Wheel replacement. (It's a great book, if you don't already have it..)
It's not a difficult repair, once you get up the courage to handle the air bag.
Side note - you could pull the fuse before getting into traffic, to avoid sending the wrong message...
Old 07-24-2011, 05:33 AM
turboflyer's Avatar
Those are the cars behind you. You are going to slow.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 07-24-2011, 08:04 AM
ProjectM96's Avatar
Haha, I actually thought that at first. But then I went to an area where I was the only car and I tested it.
And since yesterday, it has not happened again.
Porsche Boxster 986
Old 07-24-2011, 12:01 PM
ProjectM96's Avatar
Yeah I have the book. If I remove the fuse, will it affect the airbag?
Porsche Boxster 986
Old 07-24-2011, 12:02 PM
