Trans noise Noise
Just curious if my trans is on its way out.
Details: 99 Boxster 5 speed w/142,000 miles normal maintenance never tracked, clutch & IMS bearing at 140K This last weekend we took the car for a weekend get away. After driving for close to an hour at 80-85 I noticed a slight whine when crusing/accelerating. This occured between 85-90 anything higher than 90 the noise went back to normal ambient noise. I drive the car regularly for ~45-60 minutes twice weekly at highway speeds and have not heard this before. My thoughts are: - Trans bearing starting to go (always go worsecase) - Wheel bearing starting to go although recently replaced with OEM part - Trans fluid which was changed at the same time as clutch was not the right viscosity. The shop used Motul rather than OEM. I'll probably try a fluid change but barring that I'll live with it until it is unbearable. Thoughts? Anyone else have a simular experience? |
We have had customers try just about everything out there, but they always end up going back to the factory fill due to noise, poor shifting, etc. The OEM stuff is a bit pricey, but it is a full synthetic and seems to do its job pretty well. |
| All times are GMT -8. The time now is 06:19 PM. |
