I purchased a Boxster, now I have some dumb questions...
Edited based on correct info:
I just purchased a ocean blue metallic 2000 Boxster, I believe a "Sport" model with two remote keys, digital CPU readout, electric seats, upgraded chrome wheels, CD changer, wind deflector, leather wrapped dash etc... It has 68k miles and detailed service records so for $10k I thought it was a great deal. I have a couple questions: 1. Can I purchase the dual cupholder that comes in the 2001+ models and move the stereo down two notches into the bottom cubby holder? 2. Is there an aftermarket Ipod type interface, like a passthrough that connects to the CD changer? 3. How do you reset the trip meeter, and does it calculate MPG per trip? Thanks. https://lh4.googleusercontent.com/-F...0/DSC00199.JPG |
Congrats! Great color combo.
Nice find. I bought my 2000 Boxster 9 months ago for the same price with similar miles.
1. Yes 2. Yes 3. Depends on if you have the smart computer that calculates MPG. I do not have it in my Boxster. In my car, I push the button by the trip monitor and hold it down for about 2 seconds to reset it. |
All the Boxsters have active on board computer access built in to the car and was an option at the time of purchase. Access can be added by pulling the instrument cluster off and unplugging it. Looking at the plug you have to tap into position #25 (don't take this as gospel as mine was done over a year ago and I was watching). You can do a couple of things, you can add the four stalk accessory by purchasing a new or used one and pull your steering wheel and installing and hooking it up or do like I did and add it as an accessory switch on the dash board. I had three empty positions and selected the garage door opener switch and hooked it up through that. Now I can push the switch and get a readout of mpg, miles left on tank of gas, temp, avg. speed and could have had the chime for exceeding speed limit but opted to not. I'll try to find the hack for this and post it here for you or you can do a search for OBD hacks on some of the sites and find it. The switch way is the easiest and least expensive the most expensive would be to have the dealer do it.
Yes, I meant Sport, not Sport design. I do not have the extra stock on mine to control the CPU, I will hold the dimmer button down and see if that resets the trip mileage.
"Ultimate cupholder", any links to this? |
BMW Cup Holders, Porsche Cup Holders, Ultimate Cup Holder - Cupholders / Drink Holders for BMW 3 5 7 Series, Boxster 911 Z4 Mercedes Audi NSX other fine cars.
Here's the hack I'm referring to.
OBC Hack |
Thanks! |
Totally off subject...Lafayette...LA or IN? ..or other?
Also,
Does Amsoil 5w-40 work on this, of is 10w-40 preferred? Is premium fuel needed, or is super adequate? |
Porsche said 92 octane was acceptable, but the minimum. Using Super will increase the chances of engine knock, since it is more likely to combust prematurely in the cylinder. Higher octane fuel has a smaller chance of combusting too early, which is needed in powerful engines where premature combustion(engine knocking) can occur. |
SmileWavy |
bad link to the hack page...
Thanks! |
Car Audio Innovations sent me a kit that i had a local shop install. I believe they hooked it up the Cd Changer slot. Charges the iphone and gets clearer sound than using the headphone jack.
Boxster On Board Computer Activation |
I installed this (link) into my 2000 Boxster S and it works great with my iPhone 3GS.
BLAU/8-POD iPod Adapter for select Blaupunkt & Becker Radios :: iPod Adapters & Interfaces :: Discount Car Stereo |
| All times are GMT -8. The time now is 05:30 PM. |
