Jupiter 911
bklyn's Avatar
Motor mount bolts, cant remove. (long)
Ok, the plastic skid plate has been removed and out of the way, the four bottom motor mount bolts have also been removed (they came out with the stud attached). Upon trying to remove the the four bolts that attach the mount to the engine, I find the two bottom bolts are way too long to clear the chassis, especially on the drivers side. Any idea's!
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 08-14-2011, 05:23 AM
I replaced my motor mount a couple of years ago and recall letting the engine down a couple of inches with a floor jack to get clearance on a couple of bolts. I've attached a link that may help.
Install Front Engine Mount
Old 08-14-2011, 01:14 PM
harryrcb's Avatar
egress has it right you need to lower the engine carefully not to pull off or damage the radiator hoses
Crazy Austrian
http://www.ws-ab.com
Old 08-14-2011, 01:17 PM
Jupiter 911
bklyn's Avatar
This was the perfect link. Thanks
Old 08-15-2011, 08:07 AM
Glad it worked out!
Old 08-15-2011, 01:55 PM
