Help with shopping list
Hi guys,
I need a few suggestions for my shopping list. My Box is up to 70,000km and I will be on holiday in the USA in October. I am looking at what I may need to replace for preventative maintenance. So far on my list is serpentine belt, spark plugs, water pump, AOS, coolant tank,braided brake lines,coolant cap, low temp thermostat. Happy for any further suggestions. I may as well buy as much as I can while our dollar is high. |
Why coolant tank? Is it cracked or broken? Those are the only reasons they are usually replaced, unless I am missing something.
But anyways, change transmission oil at 90,000 miles, which I think is around 120,000km. Check RMS seal and IMS for leaks or issues.
Porsche Boxster 986 |
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
If you get a water pump buy the OEM one the rest are junk and even the OEM isn't made well. How about some new brake pads?
IMS bearing kit and rear main seal. For sure.
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
I have the LN IMS and a new clutch pressure plate and flywheel were fitted last year.
Purchasing the coolant tank because it is $120 cheaper in the US and don't know when I will be back. Had not thought of brake pads. |
Fuel filter. Spark plug tubes and/or tube o-rings.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor |
