Bleeder valve opening on its own
Hi,
I am trying to troubleshoot high coolant temperatures (210 ~ 220) and
* replaced thermostat with lo-temp LN thermostat
* replaced water pump
So now I had to bleed the system. For convenience I left the plastic cover (the one which hides the bleeder valve) off for the moment.
This afternoon when I came back from lunch my water temp was 215 F, all fans were running at full speed and when I opened the rtrunk I noticed that the bleeder valve had opened on its own (it basically popped out as if I had manually bled it) - is this normal?
2009 Carrera 4S, PDK
1990 964 Targa
2018 Range Rover Velar
Old 08-23-2011, 01:08 PM
This is normal. When the system builds pressure it opens the valve....have you checked your antifreeze level? The wrong ratios can cause high temperatures as well.
If you don't live life on the edge, you take up too much space.
Old 08-23-2011, 08:47 PM
