I've never had head light bulbs do this before.
When I bought my car one main head light bulb was burned out. I replaced them with some hella h7 blue bulbs. I don't remember the exact type but I do recall them being off road only. But I've used off road bulbs before without issue..until now. At first I thought I was getting fungi or something on the inside of the headlamp. Then after close inspection I noticed it was burnt from the inside out and on lamp has a small hole in it now. I'm now going to have to buy 2 new headlamps unless I can find some used..not to mention new headlight bulbs that won't burn the plastic. Any suggestions? Also is there any danger in the lamps until I can buy another set? TIA |
just about anything over 55Watt will burn the plastic
Crazy Austrian http://www.ws-ab.com |
That is weird, I have the same bulbs in my Boxster.
Hella H7 blue bulbs that shine white. Before I installed them, I already had a crack with a yellowish burn inside my right headlight. After I installed the new Hella bulbs, nothing changed. It did not get worse. My Left Headlight still looks like new. I have been running the Hella H7's for maybe 4 months now, but the most I had them On continuously was for an hour maybe.
Porsche Boxster 986 |
1st poster seems to be running the 100W off-road version, you might have the 55W version.
'02 Boxster S Tip 3.4 |
Author of "101 Projects"
It's a wise idea to only run the recommended bulbs. If you want to go with a bit more illumination, then I suggest an HID kit like the one that I installed here: Pelican Technical Article: Budget Boxster HID Headlamp Retrofit - 986 / 987
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
by the way, when I was looking at several boxsters for sale, the majority had yellowing lenses inside the headlight casing. Mine is beginning to do this now, and have only run the standard bulbs.
1982 911 SC 3.0L |
