CDR-210 fit in a 2003?
Will a CDR-210 from a 1998 Boxster, and corresponding Nokia amp, plug and play in a 2003 Boxster?
Connections looks the same. Thanks Phil |
Hi Phil356,
It'll probably fit. I took one from a 996 and installed in my '86 Cab. Problem though, was that the display was nearly impossible to read, due to the lower placement in Boxters and 996s of the radio in the dash. If you already have the system, or its really cheap, try it out. Best, Lars
"Auf geht's Burschen!" Blutorange '73 2.4T Targa, Guards' Red '81 Ruf SCR 34 Tribute and assorted 3.2 Liter Carreras at "The Road Trip of a Lifetime" |
Wouldn't the MOST bus in the 2003 negate using the early radio?
Accrochez-vous bien de vos rêves..........." |
I thought that they went to the MOST bus in 2003 - if so, they are not interchangeable. What radio does a 2003 come with standard?
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
