Rick (guest)
Guest
Posts: n/a
I have the problem that my key will turn off but will not come out of the switch. I have done everything except grip it with vice grips and it just will not come out. I can start the car and drive it, then when I stop I have to leave the key in it. I have tried the paper clip in all positions but the cylinder will not come out. Any ideas.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987
Old 09-04-2011, 08:43 PM
Author of "101 Projects"
Wayne 962's Avatar
The actual tumbler is spring-loaded. Your key sits in your pocket along with gunk and other pocket stuff and this gunk can build up on the inside of the mechanism. This is not terribly uncommon. A quick remedy when the key is actually out is to spray some WD-40 in there to loosen up the mechanism. This problem can also be caused by the steering lock - a part that was recalled and later replaced by an updated version from Porsche for issues like these. Try shaking the steering wheel repeatedly in both directions while trying to remove the key. Then, if/when you get it out, I would recommend upgrading to the later-designed part (the procedure is located in our tech articles section).
- Wayne
