Pa3.4l (guest)
Guest
Posts: n/a
I have a 1998 boxster. While sitting in the car I pulled the handle to open the door and heard a snap.. The window drops but the door will not open. However if I use the outside door handle, the door will open but you really have to pull up hard as if something is catching to open the door. What can it be?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Door Lock Mechanism / Boxster Door Handle - 986 / 987
Old 09-04-2011, 11:43 AM
Author of "101 Projects"
Wayne 962's Avatar
It's definitely one of the small plastic pieces that connect the linkage inside the door. The article shows you how to replace it - you just need to pop off the door panel and take a look inside to see exactly which piece broke.
- Wayne
