-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   5-Speed manual fluid fill clarification? (http://forums.pelicanparts.com/boxster-cayman-forum/628166-5-speed-manual-fluid-fill-clarification.html)
rpjasin (guest) 09-04-2011 08:53 PM
This article is confusing on the 5 speed transaxle. Why do you state "Pump the transmission case full of fluid until it just starts to run out the filler hole", and later in the article it states that the oil should be "11 mm below the plug opening"? Please explain, Thanks!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Differential / Manual Boxster Transmission Fluid Change - 986 / 987
Wayne 962 09-04-2011 08:53 PM
Sorry about that, you're right. That's for the six speed (fill until it runs out of the hole). The 5-speed should be a little bit less. I don't know why Porsche made it this way, nearly every other transmission on earth does it where you fill it up to the bottom of the filler hole.
- Wayne
Canuckballer 04-21-2020 08:07 AM
My filler plug is a star shaped that I took out with a 9 mm hex. It also seems to be higher relative to the axle. 986 1999 Boxster. The filler plug has a round dipstick like protrusion. Have I pulled the wrong plug?
husker boxster 04-22-2020 05:31 AM
Can you post a pic?
lkchris 04-28-2020 08:17 AM
Fill plug requires special tool
https://www.ebay.com/itm/HAZET-2567-16-Oil-Service-Socket-for-Porsche-VW-Audi-M16/231228010019
