bar10dah's Avatar
Vacuum Lines
Still working on the intake air leak in my '99 Box w/ 70K miles. Related codes P1124 and P1126. I think Porsche today said codes 27 and 35.
I'd like to replace vacuum lines labeled 25, 26, and 27.
What size lines do I need to order? PET doesn't say a part number, just says:
#25 120 mm
#26 40 mm
#27 240 mm
Looking at Pelican's site, they list sizes (I understand ID is interior diameter and OD is outer diameter):
3.5 mm ID, 7.5 mm OD
5 mm ID, 10 mm OD
7 mm ID, 12 mm OD
9 mm ID, 14 mm OD
12 mm ID, 17 mm OD
14 mm ID, 17 mm OD
So, the numbers don't translate directly. How do I figure this out? How much of what size lines do I need?
Old 01-25-2012, 07:00 PM
Paul V
paulv's Avatar
The 120, 40, and 240 mm sizes are the hose lengths. Do you have any info on parts 19 & 21 in that diagram, like the diameter of the mating nipples that the hose need to connect to? The other alternative is to remove a hose and measure the ID and OD.
Regards,
paul...
07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X
Old 01-26-2012, 05:16 AM
bar10dah's Avatar
Ah, makes sense. Thanks Paulv. Looking at the hoses, they do appear to be about those lengths.
Old 01-26-2012, 06:35 PM
bar10dah's Avatar
Based on the information from Paulv, I relooked at the PET. Maybe that part number above those hose lengths is the part number, 000-043-205-01, for that hose. Appears then that the size is 4 x 1 x 210 mm.
So, if those hoses are 4 mm, will a 3.9 mm do the trick? Autozone didn't have any metric sizes, so I bought a 5/32" OD hose which is also marked 3.9 mm.
Old 01-26-2012, 07:23 PM
Paul V
paulv's Avatar
That's a good question since the difference is 0.1mm (0.0039") which doesn't seem to be critical since it's within 2.5% tolerance. You're probably safe buying the 5/32 hose. Good luck.
Regards,
paul...
Old 01-27-2012, 04:39 AM
