-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Temp display with On Board Computer (OBC)? (http://forums.pelicanparts.com/boxster-cayman-forum/628254-temp-display-board-computer-obc.html)
Designprof (guest) 09-05-2011 11:35 AM
I have a 1999 Boxster. I was told by my local Porsche dealer that this OBC upgrade will not work on my car because "it wasn't installed". However, I have an outside temp indication below my mph readout so doesn't this mean I have it? Will this upgrade work for me? I don't want to mess around with the electricals unless I am sure. Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster On Board Computer (OBC) Upgrade / Boxster Turn Signal Switch Replacement - 986 Boxster (1997-04) -
Wayne 962 09-05-2011 11:35 AM
Again, dealers are pretty clueless and often don't know much outside of the scope of what's in the factory manuals. It sounds like a previous owner might have already turned this on in your car to allow you to see the temperature display.
- Wayne
bar10dah 09-08-2011 10:21 AM
From everything I've read, if you have a temp display, your OBC is already turned on.
Mine was displayed. My Durametric arrived today. Sure enough, it says my OBC is activated.
I've got a few more projects I'd like to do first (the next big one is upgrade to the ROW M030 suspension, Project 63), but I will eventually do Project 91 to be able to access the rest of the options for the OBC.
Rink 08-02-2012 07:10 PM
Anyone know where the outside temp sensor is located? Anyone know the temperature range?
Thanks,
Rink
Wayne 962 08-02-2012 11:40 PM
There is an outside temperature sensor located in the front bumper cover. See photo 1 of this article: Pelican Technical Article: Boxster Front Bumper Removal - 986 / 987
-Wayne
nosnow4pc 08-04-2012 09:17 PM
I have a 99 also and likewise I had the temp displayed. I did the upgrade and it works perfectly.
