-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   2002 tiptronic transmission temperature sensor??? plz help!! (http://forums.pelicanparts.com/boxster-cayman-forum/631689-2002-tiptronic-transmission-temperature-sensor-plz-help.html)
rabidewok 09-26-2011 02:22 PM
I have Code 37 showing on my durametric software. Durametric is telling me that it is a transmission temp sensor. I cant find any info on this and i need a part number. Plz where do i find this info?? thanks in advance!!!!
JFP in PA 09-26-2011 03:56 PM
The news ain’t good on this one, the sensor is supposedly “integrated” into the wiring harness for the trans, and requires replacing some or all of the harness to replace. Some good reading on the subject:
http://www.europeantransmissions.com/Bulletin/DTC.Porsh/lib_download.jsp_file=por_G40tiptronic_diagnose.pd f
NewArt 09-22-2013 08:04 AM
Hi, Did you get this problem worked out?
NewArt 09-22-2013 01:19 PM
Thanks for your response to my email Rabidewok. Hopefully my problem is not so dire! :eek:
