Oil pressure gauge for the 987
On another site, there was a thread about using the Sportchrono "wart" to hold an oil pressure gauge rather than a stop watch.
I like this idea a lot--here is one example:
http://www.westach.com/gauge_images/2DA3KV.jpg
My question is:
I understand --from an earlier thread--the oil level sensor on a 986 also functions as a oil temp sensor; does the 987 also have the capability?
Thanks for any help.
Old 04-11-2012, 12:30 PM
Paul V
paulv's Avatar
I thought about doing this a while back as I saw some nice gauges in an issue of Excellence. They were fairly expensive as I remember.
The 987 also has the oil level and temp incorporated in the same sensor. The oil pressure is just a switch.
That company made the two separate gauges with 5 volt signal feeds (for DME/OBD2 interfacing) and used the OEM temp sensor and offered a pressure sensor to replace the pressure switch.
Sent you a PM.
Regards,
paul...
07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X
Old 04-12-2012, 05:08 AM
replacing the oil pressure switch with a combo of oil pressure sensor and switch (for the warning light) is very simple (look at Wayne's book, it's described here)
Pelican Technical Article: Boxster 996 Gauge Cluster Upgrade - 986 Boxster (1997-04) -
I was looking very long for a way to get to the oil temp and could never figure out how to tap into the built in oil temp sensor but eventually found an additional place where I could install an oil temp sensor
Oil temp sensor - 986 Forum - for Porsche Boxster Owners and Others
This is on a 986 but I'd think it would be worth to check if that also works on a 987
2009 Carrera 4S, PDK
1990 964 Targa
2018 Range Rover Velar
Old 04-14-2012, 08:00 AM
turboflyer's Avatar
It needs to match the cluster to look right, IMHO. I did a set up for my 01S Boxster. Never actually hooked up the sensor but it looks pretty cool. Mounted the gauges on what was a porsche phone mount. Not sure what year you have. I can post a pic if anyone would like to see it. Might even part with it.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 04-14-2012, 09:07 PM
This would replace the typical sportchrono "dash wart" in a 987.
Old 04-15-2012, 09:48 AM
I totally like the idea of putting this into the "wart"
1990 964 Targa
Old 04-15-2012, 12:37 PM
