Here is an update on my 01 Boxster 2.7 oil change experience. I'm hoping this will answer some questions. I have to say the Pelican Parts send me the right parts, the first time and FAST. Oil filter wrench / oil plug / crush washer
First, don't waste you time getting an oil filter cartridge and filter wrench from one of the chain parts stores! If the filter is made in China, eg STP, you will have problems fitting it around the oil pipe. Also that type of filter has a larger top and bottom rim reducing the space between the filter housing and the cartridge by a significant amount. That means possible reduction of oil flow through the filter.
I went to three different part stores using a total of 8 different filter end wrenches, none of them fitting correctly. Get the Porsche wrench from Pelican Parts and avoid the frustration!
Secondly, I had the same issue of the 8MM hex not fitting in the drain plug. I had to use a t-50 torx to get the plug out, no crush washer there also. Replaced it with new plug and washer, also from Pelican Parts.
And lastly, my Boxster has over 110k miles on it, so I added about 9 quarts of dino oil 10w 40 and I'm good to go.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Oil Change - 986 / 987
Old 11-10-2011, 09:40 AM
Jupiter 911
bklyn's Avatar
Good post, the only thing I would change is the long debated type of what oil to use. I have always used Mobil 1 10w-40w in my 2002 Boxster with 85k on it. It was the orig. fill from the factory, thats what I remained with.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 11-11-2011, 04:28 AM
ronster's Avatar
I've been using the factory recommended Mobil 1 0-40w in my '99 for the three years I've owned it and started noticing some valve clatter on start up. I recently won a case of Royal Purple in a photo contest and selected their 5-40W and had it put in a month ago at 5000 mi oil change interval and have had no valve clatter since. RP is more expensive but I'm going to switch to it.
Old 11-11-2011, 07:16 AM
Jupiter 911
bklyn's Avatar
Ronster, just a thought, maybe the 0-40w was just a little to light for our cars. I have zero clatter with the 10-40w Mobil 1. Just another alternative.
Old 11-11-2011, 12:58 PM
ronster's Avatar
It gets a bit hotter where you are than NorCal but I do agree that the 0-40 wt. is probably too light especially as the miles get higher. When I bought the car at 74K there was no valve clatter on start up until it hit around 95K.
Old 11-11-2011, 03:44 PM
