markgl (guest)
Guest
Posts: n/a
To just replace the radiator fan do you have to drain the coolant and remove the radiator, or can you leave the radiator hoses connected and just remove the fender brace, the rad support frame and then the fan housing?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Radiator Replacement and Cleaning - 986 / 987
Old 11-18-2011, 02:45 AM
Author of "101 Projects"
Wayne 962's Avatar
I believe that it's possible to remove the fans from the radiators without actually disconnecting the radiator hoses. However, I have never done it in this order, so I will copy this question to the forums so that someone there can confirm?
- Wayne
JFP in PA's Avatar
Yes, the fans can be swapped out without draining the cooling system; you will need to remove a bunch of things that are in the way, which is not hard, but is time consuming. Be sure to clean out the accumulated crud in the area as well.
Accrochez-vous bien de vos r๊ves..........."
Old 11-18-2011, 08:04 AM
