-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Tips on removing headlamp switch... (http://forums.pelicanparts.com/boxster-cayman-forum/639588-tips-removing-headlamp-switch.html)
Lukeman (guest) 11-12-2011 10:20 PM
Help! This comment is about the picture at Figure 3. I pulled off the side vent and headlamp switch together but removing the switch must involve more than simply unscrewing the large nut on the face of the bezel. I removed the large nut and still can't remove the switch. The replacement switch has lugs on it. It appears that the old switch has lugs too. Can't figure out how to rotate the lugs to the slots so it will release.
Followup: This is a follow-up to my earlier request for help. I figured it out. The light switch circuit board connected to the harness has to be pushed out to rotate the switch so the lugs can be pulled out through the slots, releasing the switch. Thanks anyway.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Headlamp Switch Replacement - 986 / 987
Wayne 962 11-12-2011 10:20 PM
Cool, thanks for the clarification!
- Wayne
