John Bosmans
Front Bumper Finish Help
Recently my front Bumper is showing signs of "peeling". Imagine a screen protector on a cell phone/Ipod.
It is bubbling and peeling. The color of the paint is fine its just this film covering it. Has anyone experienced this? How would I go about correcting it? I seems like I could peel off the film and then clear coat it?????? |
I assume you know the difference between clear coat and a 3M type product that covers the bumper? If it truly is clear coat peeling, that would not be factory and someone resprayed it at some point.
My suggestion? Remove the front bumper cover and have it professionally refinished...doesn't cost that much and it's quite easy to remove DIY.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
John Bosmans
It is not 3m.....it is def. the clearcoat. the paint underneath looks great.
I saw a can of clear coat remover at Auto Zone Yesterday.....could I just remove the flaking clearcoat and then reapply new clearcoat? |
John Bosmans
Here is a pic.
Now, on the other hand, if you wetsand (without removing any of the color layer) and re-coat that little spot... then wetsand the new clearcoat, and polish to blend, maybe it will look good enough for you... but I seriously doubt it. Likely, you're going to refinish anyway, so it won't hurt to try (avoid waxing, though... rubbing compound and polishing compound only. Wax can cause "orange peel" issues when recoating). Good luck. |
