Jim (guest)
Guest
Posts: n/a
I just replaced the AOS however, it still bellows a huge amount of smoke and the rough idle. Can you give me some suggestions?
Update, thank you for the great DYI info. After replacing the AOS I started the car while still on the jack. My 16 yr old son said that maybe if it is a flat 6 and on the angle of the jack the oil is in the pistons. Bingo! He has been begging me to teach him how to drive the porsche and I think he just earned his ride.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Air / Oil Separator Replacement - 986 / 987
Old 11-12-2011, 10:49 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, that will happen perhaps. More likely is that the oil is still saturated inside of the intake and will need a few miles to "blow itself out." It's very common to have significant amounts of smoke upon startup after replacing the air-oil separator on the top of the engine.
- Wayne
