EIFFEL (guest)
Guest
Posts: n/a
Do you know approximately how many labour hours to change the 2 convertible top push rods with the roof alignment after the replacement?
Mine is a 2005 987 Boxster.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Convertible Top Repair - 986 / 987
Old 11-12-2011, 10:51 PM
Author of "101 Projects"
Wayne 962's Avatar
I'm not sure, it's a bit of a loaded question. Typically, you don't need to replace these unless something disastrous has happened to the roof. If that is the case, then often there are other components that are damaged, and simply replacing the rods won't necessarily fix the problem. However, to answer your question, it would probably take me about two hours, assuming that is all that is needed to be done.
- Wayne
