2004 Boxster engine
I need to replace the engine in my 2004 Boxster (intermediate bearing failure)
What other 2.7 engines (years) will fit without modification?
Does anyone have a line on a good used motor?
I will be upgrading the bearing in the new motor
Bill
Old 05-28-2011, 08:12 AM
03 - 04 engines are identical not sure how new you can go 05,06,07? several 2.7 on E-bay. Check Pelican parts engine exchange tech article.
Old 05-28-2011, 09:54 AM
JFP in PA's Avatar
I'd stay away from anything newer than an 04 due to the problems changing out the last revision IMS bearing.
Accrochez-vous bien de vos rêves..........."
Old 05-28-2011, 10:11 AM
s_wilwerding's Avatar
If I had a 2004 that I had to put a new engine in, I would definitely be considering at least a 3.6, and maybe a 3.8. Wayne's got a good article about the engine swap, and you'd find that the bigger engines will not be that much more expensive than the Boxster engine.
Something to consider.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 05-28-2011, 04:21 PM
Thanks! I was considering the upgrade but I think I just want to get it back together and go driving!
So I should stay with the 03 - 04 engine?
Thanks.
P.S. would a 3.2 S be a direct fit (no modification)?
Old 05-28-2011, 07:30 PM
harryrcb's Avatar
Thanks.
you would need to reprogram you DME other than that I think you are good to go with that.
Crazy Austrian
http://www.ws-ab.com
Old 05-28-2011, 08:36 PM
Bill,
How many miles were on it before the IMS went?
GEorge
Old 12-17-2011, 04:57 AM
Originally Posted by georgedean View Post
bill,
how many miles were on it before the ims went?
George
61,000
Old 12-17-2011, 05:45 AM
harryrcb's Avatar
there is not telling when those suckers go. I have replace a dozen or so recently (IMS bearings) with varying mileage and some were totally fine and other were just starting to fail (binding bearing) with just minor seepage or weeping. others were leaking profusely. It's good insurance just to get it done and not worry every time you turn the key if it's the last time.
Crazy Austrian
Old 12-18-2011, 07:44 AM
