Where to place jack stands after lifting the car?
I have read the information on lifting the Boxster at the jack points but am unclear where to then place he jack stands in order to remove the jack.
Thanks, Paul |
I need this information as well.
I confess I have not looked in my Bentley yet, was hoping someone here would be willing to post the solution.
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold |
Not exactly what the Bentley manual recommends and what I do (particularly at the rear).
Thanks MJ, Seems like a reasonable solution to me. There is an oil change in my future.
Here's Bentley's recommended method (see the circles). Works for me ...
Author of "101 Projects"
Here's a clip from my new book:
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
When's the book coming out, Wayne?
Thanks Wayne! And yes when is this book coming out? We need it!
Sept or Nov 2009...
-Wayne
Wayne, thanks for the preview of your new book. I tested the jacking procedure for the rear of the car over the past couple days. I can say that your procedure works well, and it is better than the procedure described in the Bently manual.
I guess this page is down. http://www.101projects.com/Boxster/1.htm
I can't view it. Wayne, I tried the method you describe. The one problem I encountered was that once I lifted one side of the rear and placed the stand, I started to lower the jack and the opposite rear wanted to come down resulting in the front lifting off the stand. Since I was planning on using my 6T stands in the rear, I had the car up pretty high. I placed a shorter stand under the other rear lift point and let the car down. Then I got under your designated jacking point and lifted the car to square up and get the 2nd 6T stand under the rear. So, an extra stand or suitable block is necessary to use your method. I agree that lifting the car in the center as the Bentley shows is probably not a good idea. Especially is using an aluminum "race" jack. Now, I see the door gaps are not quite right with the car up on the 4 factory lift points. I think I'll put that 5th stand under the cross member in back with just a little pressure, not so much as to take much weight off the rear reinforced points. Just to relieve some of the stress on the body. I plan on having the car up for a few days. |
In general, if you have the car on five-points, it may not be as stable as with four points, as it's difficult to balance completely. In reality, if the chassis doesn't flex at all, you will only be supported on three points (restricting three degrees of freedom). The car is a convertible, and it's designed to have the weight supported in four corners of the car (by the wheels). I wouldn't worry about the chassis flexing - my car was up on jack stands like this for several months. Hope this helps, Wayne
Today, I took the car down off the stands. I place the jack first under the driver's rear sway bar point as Wayne suggests. This time the car came up evenly and I removed both rear stands. Then I removed the front stands from each side with the floor jack at each side, one then the other.
I guess I'm doing it right. I'm a bit afraid of using the pinch seam found at the bottom of the rocker. But, if I had a strip of something to distribute the load along that seam, I would use it. It would have to have a groove in it to fit over the fin. |
Looks like you are jacking the front end of the car. Are you saying the rear alternate jacking point is close the rear jacking point? I need to get under the rear end to change the oil on a 2003 boxster S.
Inquisitive user
Check this out. It may help you. Randy
Perpetual change. It will happen!!! |
