Sir Laffalot (guest)
Guest
Posts: n/a
I don't see where you mentioned the size of the hose that one needs to drain the gas tank: 1/4-inch I.D. polyethylene tubing. It's not clear which makes it hard to see when gas goes into the line, but it's fuel-resistant. Regular clear vinyl will work too, I guess, but it might work next time.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Fuel Pump Replacement - 986 / 987
Old 12-18-2011, 12:10 PM
Author of "101 Projects"
Wayne 962's Avatar
The clear vinyl hose works fine for short term emptying of the fuel tank like this - it's not going to eat through or dissolve the hose while your emptying the tank. I wouldn't use it long term, but for short term usage like this, the clear hose works well.
- Wayne
