John Bosmans
John99Boxster's Avatar
986 Ground Clearance
Does anyone know what the standard ground clearance is for the 986 using 17" tires.
OR
The clearance between the rear tire and the edge of the wheel well?
My 99 seems to have very little tire to well clearance (less than 2 inches).
Maybe I have a different suspension package?
1999 Boxster
Midnight Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | Glass Rear Window
Old 12-20-2011, 04:54 AM
Certified Porsche addict
The Glademister's Avatar
We put in coil-overs on our '99 Boxster so those measurements will be off from OEM. However, I do remember that with OEM suspension, OEM 17" wheels and OEM tire size we measured 5 1/2" ground to jack plate (within 1/4" all corners). What will help others figure out your question is your current tire size though. That changes wheel well clearance. If you've got aftermarket struts, that should be apparent. I'll attach a photo of a 987 strut which looks the same. Also, check your option codes. If you've got the Sports option it should be on there.
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 12-20-2011, 07:08 AM
John Bosmans
Im running 17s
1999 Boxster
Old 12-20-2011, 09:09 AM
