-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Who has done an IMS change (New Oil Fed Design Idea) (http://forums.pelicanparts.com/boxster-cayman-forum/649905-who-has-done-ims-change-new-oil-fed-design-idea.html)
feelyx 07-05-2012 10:30 PM
are those 2 lifters stuck in their bores? those valves could be bent shut and weren't opening at all for some time.
feelyx 07-05-2012 10:33 PM
actually my bearing idea removes the flex from the case as the shaft has no pivot point anymore and it doesn't use the bearing like a lever, like the orginal system setup.
feelyx 07-05-2012 10:41 PM
Ideally the case needs 2 beefy pins around the ims hole, to keep the case halves from flexing independent of each other in that area.
harrisracing 07-06-2012 06:42 AM
More info
The evidence that points the lifter collapse to having been prior to the IMS failure is as follows:
1) NOTICEABLE dings in the pistons that hit valves...but NOTHING in the intake valves that have collapsed lifters.
2) The lifters have been curved out by the flat camshaft hitting them THOUSANDS of times before the the IMS failed and killed the motor. Think about it...they don't look like a cam banged against them 50 or so times before dying...it was a long gentle hammering process - NOT just a few hits that made dents - they are perfectly smooth and that kind of work took thousands of hits to get right.
3) They slide in and out of the lifter guide perfectly - Nothing stuck whatsoever.
4) I'm not the only one with this problem. Lots of collapsed lifters on Boxsters without being related to IMS bearings. Of course...
5) Trash in oil from the IMS failure may have plugged up the lifter feed lines assisting in their collapse.
feelyx 07-06-2012 10:10 AM
Do you know if the engine have a consistant ticking sound?
Are you able to open the lifters up to see the springs inside if they are broken?
I have a complete set from a 98 2.5L, if they fit you are welcome to them <40,000mi.
PorscheMallorca 07-10-2012 02:10 AM
Sorry Feelyx
I was away due to our montly event (Porsche Club Baleares) I will try to continue posting more info
Thanks ;)
Vizor 07-10-2012 03:23 AM
Harrisracing,
I would also love to see the springs inside of these lifters, if you can post pictures and/or measure them I can compare it to pieces of very small spring I found in my oil and don't know where it came from.
harrisracing 07-10-2012 10:29 AM
Will do
I will get dimensions of the springs and such inside the damaged lifters.
Patrick
PorscheMallorca 07-13-2012 09:26 AM
Dear board members
Donīt you think one row bearing system is weak than a double row bearing system
http://forums.pelicanparts.com/uploa...1342200211.jpg
http://forums.pelicanparts.com/uploa...1342200259.jpg
Why this change, I have a lot of pictures of single row damaged bearings and few of double row
What do you Think?
Brando 07-21-2012 02:56 PM
Quick bump... how goes progress?
Also, quick question on the externally oil-fed design... How well does this work on an IMS Bearing with just the outside-facing seal removed?
I just picked up a 2006 with 3.4 L engine and my only concern since the bearing isn't service-able , how could I keep it lubricated to prolong it's life, without blowing off the seal on the interior side?
Thanks...
feelyx 07-21-2012 05:56 PM
Hi brando...SmileWavy
Everything is running great, I have had no problems with the bearing. I've put over 5k mi. on it and had just changed the oil, the microscope didn't show any heavy metals, I will send it to be tested soon.
The oiler set up will work with the standard setup. I drilled the IMS housing to except a 1/8" pipe fitting below the main shaft. I also silver soldered a 1.5mm jet at the end of fitting pointing towards the bearing. There is a pic somewhere in this thread. If you drill the oil galley, do not use steel tubing to the bearing housing as it will crack eventually with the standard setup..... Use 2mm id pfte high abrasive tubing.
The oil pressure will not blow the seal on the otherside out, the balls and cage break up the flow to the seal. I could not take out the seal with the 1.5mm jet at over 100psi anyways.
Just make sure your bearing is in very good condition, as no amount of oil will save a bad bearing. It must not wobble, or have any rough feeling when spinning.
There is a video of the stock bearing running with the oiler in this thread also...
Good luck and post some pics too....SmileWavy
Vizor 07-22-2012 09:41 AM
Feelyx, Just looking back through all the posts and wondering if the bearing could be fed internally if the modifications were done at the time of a total rebuild. I realize your intent here is a simple retro fit solution, but looking at the pressure fed IMS tensioner nearby I thought there may be a way to tap its oil source internally. Where exactly does the IMS tensioner get its oil supply? Is it fed from the 4-6 head or the crank supply gallery, or? The Porsche oil schematics I've seen do not even show it at all.
feelyx 07-22-2012 11:37 AM
Hi Visor.....SmileWavy
Did you locate where the spring piece came from?
The closest oil galley to the IMS is in this pic it actually feeds the tensioner. I would not recommend tapping into the tensioner galley itself as the hole is barely big enough to support the tensioner.
I am not sure if you would have enough room to locate a line internally, that would not interfere with moving parts.
http://forums.pelicanparts.com/uploa...1342985837.jpg
Vizor 07-22-2012 12:24 PM
I can't say for certain I located where the spring pieces came from, but I did just remove the 1-3 tensioner and a bunch more pieces just like the ones I found in the solenoid finger screen above it fell out with the tensioner. I cut open the tensioner and then cut open the check valve inside, but there was no evidence of a small spring...just one more piece floating around inside. So either the check ball valve in this case does not have a helper spring, or it completely disintegrated which is a real possibility since all the pieces were quite smashed and mangled.
If the variocam plus engines flow oil to the 1-3 tensioner just like the older variocam engines, then this tensioner is fed directly from the same port in the head that feeds the timing solenoid/actuator. It would make sense that I found the same debris at this solenoid screen, except that to get there from the tensioner it would have to move against gravity and the oil flow direction. I guess if the tensioner check valve has failed then the chain could smack the tensioner piston hard enough to fully compress it, shooting a bunch of oil out the inlet port and up the gallery, especially if the vane cell adjuster was taking in a lot of oil at the same moment and the oil flow direction in the tensioner gallery reversed momentarily. It seems more likely that it came from somewhere before either of these devices, but if so where? Only thing I can think of would be the check valve for the piston oil squirters, but if that blew out I would think the main bearings nearby would be starved of pressure and I would have spun a bearing by now.
I also removed the IMS tensioner and didn't find anything and it seemed ok, but I replaced it anyways since I was that far into it. I am in the middle of putting everything back together now. So, do you know the oil flow routing that leads to the IMS tensioner?
feelyx 07-22-2012 04:21 PM
Vizor,
Here is a spring out of one of my lifters, its .66mm/.026 wire, 5.50mm/.217 diameter, 7.46mm/.293 spring length. I was popping the balls out looking for a spring around the crank, but couldn't find any yet.
http://forums.pelicanparts.com/uploa...1343002908.jpg
Vizor 07-23-2012 12:18 PM
Originally Posted by feelyx (Post 6870179)
Vizor,
Can't be that spring then. The debris I found is 0.16mm/.0065" wire...so much, much smaller. Obviously can't tell the original coil diameter or free length from the pieces.
The check ball spring inside the timing solenoid filter screen is 0.16mm/.0065" wire, 5mm/.197" diameter, 12mm/.472" length without about 5 active coils.
Popping what balls out, the piston oil squirter valves in the crank carrier? What do those valves look like?
feelyx 07-23-2012 12:34 PM
I will get some pics up for you soon, including the tensioner oil galley.
intakexhaust 07-24-2012 07:10 AM
Feelyx- Great stuff and nice work. Its an excellent solution to what I've been saying from the very beginning. Completely in your camp on this one. (Are you selling a kit?) The original design for a radial bearing load in that end without any pressure relief is going to have a shortend life span. IMHO Porsche straight out missed this. The bigger and ceramic type upgrade whatever replacements can get away with it, but just an engineering band-aid. Regardless of which theory and upgrade one does, at least for now they all seem to do the job, hopefully for a normal life expectancy of a vehicle. Cheers to you, Scott
Originally Posted by intakexhaust (Post 6493664)
I sort of look at it in a more simple view. For the RMS, the distance from the crankcase end and the inner is substantial along with it operating under a vacuum state should suck the lip seal inwards.
Now when we consider the IMS seal and bearing, you would think its the same behavior but its not. For the moment disregard the high volume oil pump of which has no relationship to where I'm going. The original bearing that is sealed in its cavity is being pressurized far greater because engine oil (from a harsh cumbustion environment) is pushing and pushing with no escape in that tiny area. That little area without oil having an escape route or orifice has no choice but to push through the bearing seal, mix and wash out the grease and we all know what happens from there. Apparently bigger bearings and ceramic type are enough to take the abuse but if the bearing housing had an orifice relief or cavity return, it might be all that is needed.
Also, from what I've read and guessing, Wayne's design has a beveled shield. Who knows what the best will be when we read these post years from now?!
feelyx 07-24-2012 08:46 AM
Hi Scott...SmileWavy
Like I said many of times in this thread..... anytime you use a bearing as a lever it will fail, and that is what Porsche did in its design. The bearing just had to be flipped around and mounted in the case.
My bearing doesn't use the rubber seal, it uses a metal shield, to hold a small reservoir of oil in the bearing and any excess oil is pushed through the shield into the sump. This keeps 30% of the bearing wet at all times, as required by the bearing mfg-er. The housing I designed will let oil exit only, no "dirty" oil will enter the bearing from inside the case, + if one should experience a bearing failure the housing will catch the shaft from damaging any components and keep the debris inside the bearing housing. Also there were a couple more mods done for strength and ease of replacement.
As a side note, I will be switching to grease lubrication in about 15k miles. Just to see if the bearing can handle the switch over with no issues.
As for sale of the bearing.... I will not be selling any... It is almost through the patent process as of right now. There are ongoing negotiations with companies to purchase licenses to produce this product. Hopefully news in 6 to 8 months. ;) It was a bit overwelming to find out who is actually interested in producing it.
Onward...SmileWavy
WeAreNotAlone 07-25-2012 07:11 PM
IMS problem.... What YEARS are affected?
Quick question:
Thinking of buying a Cayman, possibly a Boxster.
IMS problem = What YEARS are affected?
