bar10dah's Avatar
Sidemarker Light Bulb
Mike Focke's webpage says to use 2825 as a replacement bulb for the sidemarker.
Phillips light bulb guide in the store says to use 12961.
Sylvania online says to use 2825.
However, all I see in the automotive stores, that look similar to the bulb I took out, which read W5W 12V, are 192 and 168.
Looking online, 192 is a 3W bulb and 168 is a 4.9W bulb. Do any of you, that's replaced this bulb, used 168 and had success?
Old 01-16-2012, 10:47 AM
bar10dah's Avatar
I swapped out my burned out bulb with a 168. Appears to be the same brightness as the other side, so I think I'm good.
Old 01-17-2012, 06:05 AM
Paul V
paulv's Avatar
A W5W bulb is a Sylvania 2825. Here's a pix for my 987 with bulb refrerences.
Regards,
paul...
07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X
Old 01-17-2012, 07:54 AM
bar10dah's Avatar
Thanks Paulv. Neither part number was available locally. I ended up using a 168 and it matches in size and perceived brightness. Wattage was off 0.1 W.
Old 01-17-2012, 05:14 PM
