-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Can I replace the brake fluid without using the PST2 or Durametric? (http://forums.pelicanparts.com/boxster-cayman-forum/651444-can-i-replace-brake-fluid-without-using-pst2-durametric.html)
khakwanit1 01-17-2012 06:46 AM
I am planning on changing the brake fluid on my 05 Boxster with the PSM. I read the article in the book and was wondering if it is necessary to use those softwares. I do have the durametric and only used it once to remove the service sign. It wasn't user friendly and don't want to mess other things up. What can possibly go wrong if I don't use the software?
JFP in PA 01-17-2012 11:44 AM
You do not need to activate any systems to bleed the brakes and clutch hydraulics. Use of a PST II/PIWIS/Durametric for activation is only required if you have gotten enough air into the system that it has entered the ABS/PSM pump and control network.
Wayne 962 01-17-2012 01:45 PM
That's correct. You *should* be able to do a bleed / swap of fluid as long as no air gets into the system. If air gets in, then you need to put the car into bleed mode...
-Wayne
khakwanit1 01-17-2012 04:26 PM
Thank You Guys
