GT Jackson
Hardwire Accessory
I would like to hardwire my XM radio into the fuse panel of my 2010 S so that is only powered when the ignition is on and engine running. Cany you direct me to the proper fuse into order to accomplish this?
Gordon
Old 02-01-2012, 04:31 PM
bar10dah's Avatar
Don't remember the row/number, but there should be a fold out attached to your fusebox panel. Pull that out, and if you don't have heated seats, find where that fuse would go and tap in there. It's only powered when the key is in the on position. I don't believe there are any fuses that are on only when the engine is running.
Old 02-01-2012, 06:56 PM
