Wheel Removal
This may be the most lame question yet, but....
I removed all four wheels from my 99 this past weekend for the first time. (I'm a relatively new owner). Wheels are stock 17". I had to actually beat the wheels off with a rubber mallet from the underside of the car. Could not pull them off for anything. Is this normal? I noticed some signs of corrosion on the "tabs" that hold the wheel in the proper place in order to apply the bolts. Perhaps they were "corroded" on and just need a good cleaning? Is there a special tool that would help? My car came with a spare and jack, but no wheel removal tools. Any advice would be greatly appreciated. Thanks!
Old 01-31-2012, 07:04 AM
ronster's Avatar
Did you look in the compartment in the back of the spare to see if there is a tool kit? The tools are in a leather bag that rolls up and should contain a socket for the lugs, a bar to put through the socket for leverage, a pilot tool for holding the rim on while you install the lugs, pliers and a reversible screw driver and possibly a center cap remover. If yours is missing you can pick them up off eBay.
Old 01-31-2012, 07:25 AM
When different metals ( steel & aluminum) are in direct contact with each other it causes corrosion. Wire brush clean the contact surfaces & a very light coat of anti-seize will help minimize the problem.
Old 01-31-2012, 08:39 AM
Mine were stuck so bad I had to lie on my back and kick the rims as hard as I could before they busted loose! Glad I was in my workshop and not on the highway!
Old 02-01-2012, 04:48 AM
Agreed. I have had this same problem on multiple cars I've owned over the years. Clean up the corrosion and prevent it from returning!
Tom Coradeschi
03 Boxster
Old 02-01-2012, 07:50 AM
Thanks for your responses. For some reason, the tools are not in the front trunk, but the foam holder and jack were. I just bought a lug wrench in case of a flat. When I put the wheels back on, I'll clean it all up and coat the surfaces where they meet. If I were to have to take a wheel off on the road, I would have been screwed.
Old 02-01-2012, 08:55 AM
One time when my wheels have been stuck on, I have loosed the bolts a little bit then driven a short distance. First turn I felt the wheel break loose.
Old 02-02-2012, 06:09 PM
