Unhappy 98 battery drawing down
Hi I'm a newbie to boxsters and this forum. My battery draws down overnight, alternator is charging at 13.4 volts. I put an amp meter between the battery and ground and have 25 amp draw. Pulled very fuse and the draw stayed the same. Access alternator and disconnected the battery cable and there is no more draw. Does this indicate a faulty alternator. Thanks in advance for any help.
Old 06-12-2012, 04:16 PM
Cajundaddy's Avatar
Or a failed ign switch. The ignition switch is a common failure and inexpensive fix. Process of elimination works. Trace the current loss and you will find it.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 06-12-2012, 04:53 PM
