Boxster almost dies...sometimes
Hi - we recently bought a 99 boxster, ~65k mi, automatic. It was in so-so condition. Got my mechanic to fix a bunch of stuff on it, but now we are having a weird issue.
Very occasionally the car starts to sputter and loses power. If you pull over, shut off the engine and start it back up, it runs perfect. If you let it sit, or try and drive, it will go on indefinately. When this happens it throws a check engine code for a fuel injector, but they said there is no issue with any of them. Mechanic thought it was a battery/ground issue but can't find anything
any other ideas?
Old 02-23-2012, 08:13 AM
Try cleaning the MAF sensor. My 99 did similar things. It would sputter and actually quit running, sometimes. You could immediately restart it and it would be OK. At Wayne's suggestion, I unplugged the MAF sensor for a short while, and the symptoms went away. In my case, a previous owner had installed a knock-off sensor that was worthless. Hope you find the problem quickly. Good luck.
Old 02-25-2012, 05:08 AM
just an update on this in case someone stumbles across it.
ended up the relay for the fuel pump was going out. Took him driving my car around for 2 days with a laptop plugged in to find it
Old 02-25-2012, 06:50 PM
