-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Another question about detecting RMS fail (http://forums.pelicanparts.com/boxster-cayman-forum/667982-another-question-about-detecting-rms-fail.html)
Turd 03-26-2012 05:05 PM
I have attached my durametric reading from "Turd" my '01 Boxster S (67,000km). These values don't seem at all like what the other discussions refer to. Are they okay?http://forums.pelicanparts.com/uploa...1332806508.jpg
Camshaft Position 1 deviation = -3.39
Camshaft Position 2 deviation = -2.20
Actual angle for Camshaft bank 1 = -0.47
Actual angle for Camshaft bank 2 = 0.03
Should I be worried? Or relieved?
harryrcb 03-26-2012 08:10 PM
Those numbers all look good the cam deviations are holding steady within the allowed +-6 deg. the actual angle for cams are going to move all over the place. You are looking good
mikefocke 03-27-2012 07:07 AM
We know you meant IMS bearing failure. RMS is just an oil leak and has no relationship to camshaft deviation.
Turd 03-27-2012 07:30 AM
You guys are fast! Yes, it occurred to me right after I submitted my post that I referred to RMS (rear main seal) rather than IMS (Intermediate shaft bearing). That's what happens when a "do it yourselfer" wants to tinker with his Porsche!
Major sigh of relief out of me knowing that my Durametric readings are not pointing to a IMS bearing failure. No guarantees I'm sure, but its better than having a poor reading and then "rolling the dice" or changing the clutch and IMS/RMS just as the weather gets good around here!
Thanks for the help mikefocke and harryrcb!
Now if I can just get it to quit stalling......
