Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
Phil (guest)
Guest
Posts: n/a
Hi Wayne, I've taken apart the door handle on my 99 boxster. The key would just spin in the door lock and not lock or unlock the door. What is the broken or worn part that would need to be replaced? It doesn't appear that anything is cracked or broken; is the cylinder just worn out and not able to spin the cam that locks the electronic lock?
What are the fix options?
Thanks,
Phil
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Door Lock Mechanism / Boxster Door Handle - 986 / 987
Old 04-10-2012, 11:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Author of "101 Projects"
Wayne 962's Avatar
The key attaches to the mechanism behind the door. Without seeing photos of your mechanism, I can't say what is broken. However, I have a set of bonus photos from this project available here: http://www.101projects.com/Boxster/Projects/078/page1.htm
Compare your handle and mechanism to the photos, and you should be able to figure out what is wrong...
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997
Coming Soon:
SPEED READ: Porsche 911 (October 2018)
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
The problems with these laws and those who write them is the unintended consequences. They never consider them or simply fail to see them.
The more you try to protect the idiots from themselves, the dumber the idiots become, and the less they take responsibility for themselves.
residential locksmith Hollywood
Old 05-08-2012, 11:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
It's long time now to reply here but you needn't to take any stress with it if you have locksmith around. I was in the same problem last month and i have called 24 hr locksmith stockton near me to fix the issue. They also won't charged much for their service, locksmith is better option in such cases as compare to dealer.
Old 12-12-2017, 01:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Well for door lock issues locksmiths are the affordable and cheapest solution. I recommend others also to hire locksmith for door lock related problems.
Old Today, 03:16 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
