tdady's Avatar
Putting a 3.4 in your Boxster? You need this!!
http://forums.pelicanparts.com/porsche-996-997-forum/676024-fvd-tuned-ecu-dme.html
Old 05-09-2012, 04:39 PM
tdady's Avatar
Wayne,
If thats the case then why didnt I need those parts when I replaced this for a stock ECU? Also why would FVD sell just the ECU and not the other parts or even mention needing them?
I believe you can replace the ECU and, if needed, just have the immobilizer reprogrammed.
Tim
Old 05-14-2012, 06:22 PM
You're right Tim.
All you need is either the programming code or the VIN of the donating car so the dealer can look the codes up in the Porsche database.
I also swapped a used DME in my 986 andhad the DME re-coded to match the immobilizer codes.
Only thing you can' t do is re-program animmobilizer itself.
FUN: 996 turbo Cab, MY2004
Daily Driver: Macan S D
Old 05-31-2012, 01:03 PM
