-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Window not dropping with top (http://forums.pelicanparts.com/boxster-cayman-forum/674796-window-not-dropping-top.html)
M332is 04-29-2012 01:58 PM
I have a new issue... when I unlatch the top, the windows no longer drop however if I manually lower them, they go up when I re-latch the top. Here is what I have done so far:
2001 Boxster S with 15,000 miles
Disconnected the battery, waited 10-15 min and reconnected it. No changed.
Bought (from Pelican) a new micro switch that goes between the sun visors. After replacing the micro switch I get the same result. Windows don't drop when unlatched however they do go up when latched.
If I depress the window switches, the windows will go full up or full down properly.
I am open to suggestions or ideas.
Vince
M332is 05-04-2012 02:18 PM
any suggestions?
