It'll be legen-waitforit
stealthn's Avatar
Ok I'm an idiot, starting a Cayman
So I'm new to the Cayman, but I hop in two feet in and try to turn the car over; nothing or a depress clutch message (it is depresssed).
So I've found if i turn the key to on, then push in the clutch and turn the key I can start it, but what's the deal here. If I'm two feet in why does it not start, or what am I doing wrong?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 06-02-2012, 07:14 AM
bar10dah's Avatar
Could it be the clutch safety switch giving out?
Old 06-02-2012, 09:34 AM
stealthn's Avatar
It's possible, do you have an exploded diagram I could see so I could check it?
Found it, i gotta get Waynes' book
http://www.pelicanparts.com/techarticles/Boxster_Tech/93-ELEC-Pedal_Switches/images_large/Pic1.jpg
Yellow arrow is the switch
Bob James
18 Macan GTS
Old 06-02-2012, 09:53 AM
bar10dah's Avatar
How about a DIY article?
Pelican Technical Article: Boxster Brake Pedal Switch Replacement / Clutch Pedal Switch Replacement - 986 / 987
In fact, pick up the 101projects book. It's in there as well.
Old 06-02-2012, 10:09 AM
bar10dah's Avatar
I was just thinking the same thing...
Old 06-02-2012, 11:07 AM
