-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Understanding Cam tensioners (http://forums.pelicanparts.com/boxster-cayman-forum/679635-understanding-cam-tensioners.html)
mojoluthier 05-23-2012 04:18 PM
I recently changed my IMS bearing/Clutch/seals in my newly acquired '02 S at 100k, right here in my dirt floored garage, but not before I built an inch and an eighth 8' x 16' wooden floor in it. The IMS bearing was in perfect condition as it turned out, but I will sleep better knowing.
When I backed out the two tensioners in my 5 chain engine, the right side one had to be removed as it held serious tension all the way out, the left hand side (IMS tensioner) had no tension on it at all and I backed it out perhaps 4 turns. Now I am losing sleep over the tensioners as it seems unlikely that no tension is right. I do hear a rhythmic (about a 1 second cycle with a definite peak in it) rattling at idle when the engine is hot only, and it doesn't seem to be loose external parts. Is a new tensioner liable to fix this? There is no oil leak at any tensioner, and though I read plenty about replacing them, there is little on why.
This car runs great, by the way. My only reference has been 101 tips and this forum.
Thank you in advance.
BYprodriver 05-23-2012 07:11 PM
The hydraulic chain tensioners work similar to hydraulic valve lifters & have some of the tightest clearances in your engine (less than .001"). So they are a likely part to get clogged with debris carried in the oil. Replacing the tensioners 1 at a time often cures internal engine noises, but if I am understanding your description correctly it maybe valve lifter noise.
JFP in PA 05-24-2012 03:02 AM
I would tend to agree with the lifter diagnosis; that said, you can try replacing the tensioners (they are a lot easier to get at than the lifters) to see it it helps. If the car has a lot of miles on it, they could be varnished or full of crud.
mojoluthier 05-24-2012 08:36 AM
I would like to hear the difference in the spring load of the two tensioners addressed, please. I am trying to understand, not just get an end game analysis. Since they are hydraulic (news to me) it may be the tight one failing rather than the low tension one. (?)
mojoluthier 05-24-2012 08:45 AM
If it were lifters the cycle would be much faster, at least 400 times a minute. My sound is like a loose body part rattle, and I can imagine it is the timing chain dragging unevenly as it has perhaps 30 flutter twacks in it on a dynamic rhythmic repetition.
tttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttt
tomk 05-29-2012 10:04 AM
hi mojo, guessing that you are a guitar guy, with a handle like that. I am new to the boxster forum but am not new to various engines and cam chain tensioners in general, including aircooled 911's and BMW V8's etc. Based onyour description and my own general background you should have tension on tensioner most if not all the way out of removing it. The tensioner works on spring force and the oil serves to dampen its response. I just bought my boxster as a project car and it rattles like hell for a second after startup so I have ordered all the tensioners, 3 of them, plus the cam locking tool to hold everything steady while i replace them. If this question is still open in a few days I can report my experience to you if you want.
Good Luck
harryrcb 05-29-2012 07:30 PM
as tomk said, the tensioner have tension to the last thread, which you will feel when you put them back on. Soooo, if you had no tension then the tensioner is hanging up. sometimes you can get lucky and soak them in degrease over night then clean them real good but if it were me or one of my customers cars I would replace it.
mojoluthier 05-30-2012 03:46 PM
This is the kind of info I seek! Thank you.
Yes, I am a luthier, a maker of guitars and violins, mostly. Put a .com on my handle and you can check my stuff out!
tomk 05-31-2012 06:38 AM
Once I get my tensioners and install them i will post an update on how much force they exerted on the way out. One question for you, you mentioned that you recently installed a new ISB, I am guessing you purchased the install kit? If so I am planning to do mine at some point for peace of mind and was wondering if you would like to sell your puller/install kit? LMK
mojoluthier 06-04-2012 04:51 PM
I have decided to replace the one tensioner, and it should arrive in a day or so. I plan to simply unscrew the old one and screw in the new one as I cannot see how the chain could possibly jump a tooth if the engine is not turned over. Unless someone saves me, but otherwise, let logic prevail: IF there is no tension on the chain now, as I believe, THEN it cannot matter if I pull the tensioner; that's my logic.
I am hanging onto my IMS tool set for the next time, or until I know there won't be one.
mojoluthier 06-06-2012 02:56 PM
OK. No one said anything, I have just finished putting in the new motor mount (the old one was completely separated!), the car is up on the stands, and the tensioner just arrived. I'll let you know if I ruin the engine. I always was a free thinker (troublemaker)!
j911brick 06-06-2012 05:27 PM
Doesn't matter is the motor is turned over. The valve springs put tension on the cam. Once the tensoner gets loose it could try to turn either way.
mattatk 06-07-2012 04:38 PM
Is it hard to get at the 4-6 tensioner? Can you remove it whilst engine is in the car?
Can you replace 1 tensioner at a time without locking the camshafts??
j911brick 06-07-2012 09:02 PM
I wouldn't try it. There is only a very, very small possibility the cams won't turn.
mattatk 06-08-2012 03:02 AM
OK, I'll get the lock.....but is the 4-6 tensioner hard to get at?
harryrcb 06-09-2012 05:22 PM
Somewhat, you have the power steering line running over top of it etc etc you will need to access it from behind the driver seat with the carpet and panel removed
(of course you knew that) It's been a while since I have had to access it so I don't remember everything but give it a shot.
mattatk 06-09-2012 09:06 PM
Thanks I'll post the results.....wasn't sure without looking if other items had to be removed first.
Cheers
tomk 06-10-2012 01:57 AM
hi a quick update since i just installed all three
-when i removed the tensioner for the IMS shaft it came out without resistance toward the end of the threads. after i got it out it was clearly stuck in its travel, after some exercise on the bench it came free but still had binding in its travel. the replacement unit had a change of design so dont be put off by that
- the 4-6 tensioner was not bad to remove, i used a 1 1/4 box end wrench to get it free and then it was easy from there, again they changed the design so you will need a 14mm allen wrench to secure the replacement
- when installing the holding fixture be careful to note that although the slot in the cam might appear to be in the right position, vertical, you might need to move the crank another 360 degrees since the slot in the cam is very slightly offset from center. the slot will be vertical in any case
tomk 06-10-2012 01:58 AM
i omitted the most impotant point , the rattle on startup is gone
harryrcb 06-10-2012 06:08 AM
Awsome, good job
Vizor 06-27-2012 03:25 PM
I think I also have the same thing going on that Mojoluthier first described, especially the rattling only at idle when its hot. Mojo did the tensioner fix the problem?
Tomk, did you happen to take apart the bad tensioners you removed? I found a small piece of tiny spring in my passenger side variocam filter screen. Just curious if the tensioners do have some sort of check valve spring in them, I think I read that somewhere. If so that might explain the noise I have and where that debris came from.
tomk 06-28-2012 09:03 AM
variocam filter screen?? wow , news to me, didnt know such an item existed. My rattling only occurred on startup. The tensioner on the intermediate shaft was stuck when i removed it, after working on the bench it came free and extended to its full length, however, i can feel a burr on its travel, could be metal debris? I did not take anything apart. Sorry I cant be of more help.
