Strange Front Fan Issue
I have an odd issue with the left front fan. If you let the car warm up normally the left fan does not come on. If you turn on the A/C it sort of turn on and off at its own will. Then once the car is hot the fan will stay on even with the A/C off. Also: the fans come on when the needle gets to the right side of the zero, the temp drops a little, but not much.
What say you? |
Just based on your description, appears your driver side low speed fan resistor may be toast.
That is what I was thinking. Where exactly is it? |
Figure 3 at this link, it's attached to the frame behind the radiator (and behind that black plastic shield, so you can't see it in the pic).
Pelican Technical Article: Boxster Radiator Replacement and Cleaning - 986 / 987 |
There are some troubleshooting steps you can take to narrow down your problem. If no one else posts them soon, I'll post it later.
Kewl; Thanks. |
| All times are GMT -8. The time now is 07:15 AM. |
